Interested in 1995 dodge 2500
I知 looking into buying a 1995 dodge 2500, wondering what are some problems that I should be expecting or should expect with the truck, and what I should be looking for exactly, right now I知 looking at one with 125k miles, automatic, clean title. If anyone has any tips or suggestions or advice please let me know
Ouch. Expect HORRIBLE gas mileage, (single digits..... and that's empty.) and parts are getting fun to find. Some parts you simply CAN'T find any more..... for the real mopar parts, and these trucks just don't care for a majority of the aftermarket replacements. That said, I commonly see them with north of 200K miles on them, still running great. (assuming it was at least half-way taken care of.) Biggest thing is the trans. Get it good and warm, and make sure it shifts properly. Aside from that, just check it out like you would any used vehicle.
Not to hijack but I will be looking at a buddies truck, 98 1500 quad cab 4x4, with 5.9 (or is 5.8? New to dodge stuff) Anyways, other than paying attention to the transmission is there anything else I need to pay particular attention to? He drives it to work sometimes, so it runs and drives. Figure its not a bad deal or a G and rust free.
Check the plenum as well. Just pull the air filter box, crack the throttles wide open, (engine off) and see if you see oil in the intake. Some is normal, (and likely burnt on to the bottom of the intake) oil pooling in there, (generally toward the back of the intake) isn't good, and means the manifold needs to come off for repair. (check out the plenum thread stickied at the top of the tech forum.)
If it starts, runs, and moves around under it's own power, its worth a grand. If it's rust free, even better.
Ah okay was wondering about the plenum. Won't have a magnet to check with but I can check for the oil. I've drove behind him a few times and never noticed any puffs of smoke or anything. Seems to be cold natured but from what he's described it probably needs a TPS and even just a general tune up.
