Turn signals
Old 09-21-2018, 06:49 PM
ohenkle's Avatar
ohenkle
ohenkle is offline
Default Turn signals
I'm at a loss. I have a 1971 Dodge Dart Swinger. My flashers work but turn signals do not. I have tried what little I know like grounds, bulbs. I have had friends who are more knowledgeable then I work on it, pulling dash checking connections etc but so far nothing has been found wrong.
Any ideas where to go now?
Old 09-21-2018, 06:54 PM
Received 3,164 Likes on 2,918 Posts
Are there separate flasher units for the turn signals, and emergency flashers? Do the brake lights work?
Welcome to DF! Moving this to the Classics section.
Old 09-21-2018, 07:08 PM
ohenkle's Avatar
ohenkle
ohenkle is offline
There are two separate flashers and I have replaced both. The brake lights do work however the backup lights stay on. I believe this is because this is a clone and the car used to be a column shift. I have secured the part of the column that would normally turn with the shifter lever so that it does not change position toward where the reverse position would have been and I finally removed the backup light bulbs completely.Oddly, and maybe unrelated but the signals worked until I installed a new speedometer cable. Since then they do not function. I have looked and it doesn't appear that anything has been broken or moved behind the dash.
Old 09-21-2018, 07:11 PM
Blew a fuse? (yeah, too easy)
Do you have a manual for the car? Wiring diagrams? I suspect you are going to need them...... I don't have resources that reach back that far......
Old 09-21-2018, 07:26 PM
ohenkle's Avatar
ohenkle
ohenkle is offline
Yes I have an original Garage repair manual for that year covering A, B & E. I'm working thru it. I was just looking for a quick answer if someone knew. I'll get it done, it's on my bucket list. lol.
Old 09-21-2018, 07:53 PM
LOL.
We want pics.
Old 09-22-2018, 04:40 AM
dodgecar's Avatar
dodgecar
dodgecar is offline
Hello and welcome.
Old 09-22-2018, 10:20 AM
Moparite's Avatar
Moparite
Moparite is offline
One flasher is for the emergency and the other is for the turn signals. I would look at the turn signal switch in the column.
Quick Reply: Turn signals
