97 Ram 1500 no spark no fuel after swap.
Hello all. New member here. Having some troubles with my truck after doing an engine swap. The engine is out of a 2001 so I used my 97 harness and swapped all sensors as well as injectors and fuel rail from the 97 to the new motor. Upon trying to start the truck it would crank but not turn over. The truck did run before the swap it just had very low compression and burned lots of oil which is why we swapped motors. We commenced trying to fix the problem. Checked grounds and all have been cleaned and replaced. started checking relays and all function when energized manually. checked all fuses. plugged in my OBD2 scanner and it says no link. It used to work as I've used it before to read codes on this truck. I am getting power at the computer input (pin A22 and pin A2 with ignition on) and the ground inputs (pins A31 and A32) to the computer are good. when I turn on the ignition switch there is no output to the fuel pump on pin C19 on computer no output on C3 ASD relay and no output on A7 Ignition coil. so it seems like the computer is not communicating since I have power and ground going in to the computer but no output signals. I have power at the OBD2 port but will not link. Is the computer fried or is there something I'm missing here? any help will be greatly appreciated!
Ruben
Ruben
If I had to hazard a guess, I would suspect the crank sensor is either not hooked up, not installed, or got destroyed when you installed the engine. It sits on the bellhousing, behind the passenger side head, and is a frequent victim of such an exercise.
Also, the 01 intake manifold isn't going to have the provision for the one-wire temp sensor for the gauge in the dash.
I will I’ll be pulling the manifold and replacing it with the one from the 97 once I get this problem sorted out.
thanks for your response!
so it turns out you were right. The wires for the crank position sensor or pinched in between the crankcase and the bell housing. I got them loose and splice them back together connected everything up and now I have fuel pressure again. I was limited on time so I didn’t get to go much further but I did try and crank it to turn it over and it did not turn over. More info to come when I have time to play around with the truck. Again thanks for the help diagnosing my issue!
Do you have spark at the plugs?
