Check engine light will not go off
This is my first posting to the forum, so I hope I have put it in the right place.
I have a camperized 1996 5.2L Ram. I do very little mechanical work on it myself, but have a problem that the mechanic seems unable to solve. The check engine light code showed problems with the crankshaft positioning sensor, and the sensor was replaced and the check engine light reset. The light came back on only a few minutes after I drove off the mechanic's lot. The code was the same and he put another new sensor on and again reset the computer. The same thing happened again and just as quickly. The light stays on constantly. The mechanic checked the flywheel as well as he could without taking it out of the car and did not see any broken teeth. I think he did something to check the computer as well.
I don't notice much difference in the driving (hard to tell because the van has had new tires and steering components, and I only drive it to go camping), but there may be slightly less acceleration power. I'm worried that some other problem will crop up and I will not be warned because the light is always on anyway. Is there something that should/can be done to resolve this issue? Thanks a lot for whatever input you can provide.
A code is not an absolute. What I mean by that is a CKS sensor code only points you to the CKS sensor, it doesn't mean the CKS sensor is the problem. It's quite possible the wiring harness either wore through or was chewed through at some point and a wire is shorting to ground. It's hard to comment much further without know exactly which code you got.
Also, these engines absolutely HATE aftermarket sensors in critical locations. (and the crank sensor is right at the top of that list.....) If the problem actually IS the sensor itself, get a mopar sensor, from the dealer, or some online distributor, but, it MUST be genuine OEM mopar part.
Hi, Alloro. The code I have now is P1391. According to troublecodes.net that means Crankshaft position (CKP) sensor/camshaft position (CMP) sensor -intermittent signal (Chrysler). Do you have any advice about this? I got the code from a newly installed OBD Check from Torque using a Veepeak INDCheck VP11 bluetooth plugin that just arrived today from Amazon. Most reviewers of this combination are satisfied that they get good data.
