Scrap yard find
Scrap yard find
Hello all,
I have a 06 4.7 SLT 4x4 auto. Last week a 3rd gen Dakota came into the scrap yard I work at so I’m gonna strip some spare parts off it. The scrap truck is also a 4.7 SLT 4x4. I know there are two options for the auto trans and the t-case in these trucks. Are either of the t-cases interchangeable with either trans? Or does one only bolt up to a certain trans?
i believe my truck has the 545RFE but I can’t remember the t-case model.
The scrap truck has a 233 t-case. There is a flex fuel badge on the tailgate of the scrap truck which mine does not have.
thoughts??
thoughts??
The transfer case should bolt in no problem. If it has badges that say awd, or the switch that says awd, then it's awd, it should still work. They both bolt up to the same transmission and have the same spline count. The 233 is electric controlled part time 4wd, the 243 is electric controlled full time 4wd/awd. As far as I can tell they have the same wiring harness and the only difference would be the label on the switch.
Your right, I do have the NV233 since it’s only part time 4x4 and I just read in the service manual the NV244 has no two wheel drive option. Thanks. I’ll rip the scrap 233 out for a spare.
As as for the motor. What’s the difference between the scrap 4.7 that has a flex fuel badge and my 4.7 that does not?
Also, would it be worth while to take the PCM as a spare, as I know those can be pricey?
thanks for the response
Not positive on the year since the top of the cab is crushed and I can’t get a door open to check. It’s before they changed the headlights and grill though, which I think was in 08. I’m waiting on a better shape one to roll in to take the entire truck. This one I’m just picking parts.
So far I stripped, t-case, alt, starter, ignition coil’s, bulbs, sockets fuses relays.
Tomorrow on my lunch break in thinking ac compressor, what ever solenoids and sensors I can easily put a socket on. Maybe pcm.
Since i cant start this one I’m holding off on the motor/trans till one comes in I can hear running.
