engine plastic cover 09 ram
Old 10-21-2018, 07:20 PM
largecat's Avatar
largecat
largecat is offline
Default engine plastic cover 09 ram
how do I remove the plastic cover on top of the engine?
Old 10-21-2018, 08:34 PM
SHO Rod's Avatar
SHO Rod
SHO Rod is offline
If it's like the 2011 Durango with Hemi and the 2014 Ram 1500 with Hemi, you just lift straight up on the front end and rear edge of the engine cover. I don't recall if you need to remove the oil fill cap first or if that was a different vehicle of mine. There are plastic and rubber "snaps" that hold the cover in place. My recall is there are four snaps, two toward the front and two toward the rear.
-Rod
Old 10-21-2018, 09:37 PM
jkeaton is offline
Pull it straight up. As stated, may need to remove the oil fill cap first.
Old 10-22-2018, 10:14 AM
Mike Sal's Avatar
Mike Sal
Mike Sal is offline
There is one "snap" type **** in the front (just left of center). Pull straight up to unsnap it then pull forward to disengage 2 pins in the back and it comes right off. I have not put mine back on after putting the motor back together.
Mike Sal
Quick Reply: engine plastic cover 09 ram
