Is it still possible to buy a lift kit for a 00-03 Durango? I will be doing quite a bit of off roading with my 03 4.7 awd it is like a bit more ground clearance
There seems to be a 'hole' for the 00-03 Durangos. I can find stuff for 04 and newer, and 99 and older, but, pretty much nothing for what you are looking for.
Hi and thanks for the reply. Yeah I knew about cranking the front and blocks for the back just would of been nice to have a proper kit.. I know there used to be one so ill just have to keep an eye out for one
Probably cheaper to fab up a solid front axle swap if you need it to be stout. It might sound like overkill, but it shouldn't take too much engineering to do a swap like that. Proper torsion bar suspension lifts tend to be thousands of dollars.
to be honest with you I agree and I have been looking swaps people have done.. it looks like that's going to be a better way to go about doing this
