2000 Dakota Sport Climate Control
Old 11-13-2018, 07:58 PM
rickself's Avatar
rickself
rickself is offline
Default 2000 Dakota Sport Climate Control
Hey all -
I finally replaced the climate control module on my 2000 Sport. Previously there was no sound of activating the different functions - it just blew up through the defrost. No draw on the engine when going to defrost or AC. After putting in the new module, I can definitely hear the switching from one function to the next but am still just getting warm air from the defrost. Will this eventually take care of itself as vacuum builds up or do I need to check something else? The replacement module from eBay was only $45 and actually came with the harness of vacuum tubes. I did not replace that, opting to unplug the existing and replugging to the replacement. I haven't had a chance to trace the vacuum line to see where the harness ends up but it can't be far - the lines aren't that long.
Suggestions?
Thanks!!
Old 11-13-2018, 09:39 PM
magnethead's Avatar
magnethead
magnethead is offline
Sounds like there is still a broken vacuum line. When there is no vacuum, it defaults to defrost. Apply vacuum and the box will start following what you set the controller to.
Old 11-13-2018, 10:34 PM
rickself's Avatar
rickself
rickself is offline
When I had the engine rebuilt a couple of months back, the mechanic said there was vacuum to the climate control. So I guess I follow the vacuum line harness to the other end and do some wigglin? If I’m that far into it, I may just as well replace with the harness that came with the replacement.
Old 11-14-2018, 05:17 PM
rickself's Avatar
rickself
rickself is offline
Quick question - is it going to be easier to pull the vacuum harness out if I remove the instrument cluster first or is it accessible from below?
Old 11-16-2018, 06:50 PM
rickself's Avatar
rickself
rickself is offline
C'mon, SOMEBODY has to know where the other end of the vacuum harness goes to.
Do I really need to disassemble the dash to replace the vacuum hose harness for the climate control?
Old 11-16-2018, 07:38 PM
rickself's Avatar
rickself
rickself is offline
Okay, found where it plugs into.
Still all defrost. I'll check the T on the firewall.
It was the T. Pulled apart. All is good!
WooHoo!!
Old 11-16-2018, 09:56 PM
Do the vents switch properly now??
Old 11-16-2018, 10:33 PM
rickself's Avatar
rickself
rickself is offline
YES!
These old arthritic hands found that connector, fired up the truck and crap it didn’t switch. So I really hoped it was the T connection. Popped the hood and there it was, hanging with one end open. Pushed em back together and success!!
Quick Reply: 2000 Dakota Sport Climate Control
