2wd lift??
Old 11-15-2018, 10:39 PM
Cody Chan's Avatar
Cody Chan
Cody Chan is offline
Default 2wd lift??
I have a 2004 2500 and was wondering if i should get a lift rlly debating the ride is rough and when it comes to bumps in the road the car bottoms out rly debating if i should to make the ride better. thx m8's
Old 11-16-2018, 08:57 AM
jkeaton is offline
What in tarnation are you trying to say? Can you please use proper English so we can read what you post?
Old 11-16-2018, 11:34 AM
Cody Chan's Avatar
Cody Chan
just wondering if i should lift my truck buddy
Old 11-16-2018, 11:54 AM
HeyYou is online now
Received 3,165 Likes on 2,919 Posts
That's up to you. What do you do with your truck? Do you off-road? Tow/haul?
Old 11-16-2018, 12:01 PM
Cody Chan's Avatar
Cody Chan
i occasionally take the truck to the fishin hole and it just doesn't cut it there isnt enough clearance but im mostly on the road doin hauls and the ride isnt smooth like when i hit a bump the truck sounds like it is scraping
Old 11-16-2018, 09:40 PM
Front and rear springs wouldn't be a bad idea for ya then. Don't do spacers in front... you think it rides rough now?
I don't think you can go much more than 2 to 3 inches without getting into some serious coin though. But, even bumping 2" should give you enough clearance for similarly larger tires. (which also gives more ground clearance.) Don't forget to have your speedo recalibrated for the larger tires.
Old 11-17-2018, 10:15 AM
Cody Chan's Avatar
Cody Chan
Alright thanks for helping a brother out and just wondering if I should get some new shocks to? very much appreciated 😀😀
Quick Reply: 2wd lift??
