Is my truck lifted? Also, are my tires too big?
Old 11-18-2018, 12:56 PM
100LL's Avatar
100LL
100LL is offline
Question Is my truck lifted? Also, are my tires too big?
New to me 2001 Ram 1500 Sport 4x4 5.9 V8!
Pictures here: https://imgur.com/a/saLq3Kd
It needs new shocks but I can't tell if it's lifted. I looked for blocks in the springs but didn't see any. However I know nothing about lifting trucks so I can't tell. Planning on getting Bilstein 5100's.
Also, are the 305/70R16 tires on it too big? I don't notice any rubbing, however I ordered BFG AT KO2 tires but the tire shop says they are too big and won't install them. If they are too big, what's the biggest size I can install?
Thanks!
Old 11-18-2018, 01:02 PM
Received 3,174 Likes on 2,927 Posts
Is your truck an Off-Road edition? If it is, the 305's will likely fit fairly well. (some rubbing on front lower control arms on tight turns.)
Old 11-18-2018, 01:03 PM
100LL's Avatar
100LL
100LL is offline
I'm not sure, I think it's a Sport because of the plastic front bumper, however I don't see any sign of the "Sport" lettering on the hood. Any other way to tell?
Old 11-18-2018, 01:04 PM
Front bumper says Sport model. If it is an ORE, it should say so on the tailgate.
Old 11-18-2018, 01:06 PM
100LL's Avatar
100LL
100LL is offline
Nope! Tailgate only says 4X4.
Old 11-18-2018, 01:21 PM
So, not an ORE. Too bad, those are nice to have. (and hard to find.....)
The tires you are looking at are essentially fat 33's. So, they likely WILL rub in various places. You could probably do 285/75R16's though...... and they would fit fine. 265's are a sure bet.
Old 11-18-2018, 01:53 PM
100LL's Avatar
100LL
100LL is offline
Thanks! I'll order the 285's from another shop. Discount Tire is the place that wouldn't install them FYI.
Any clue on my lift question? Is there any more info I could provide to determine if it's lifted?
Old 11-18-2018, 01:57 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
There are 2 around me but are rusted out. I would just like to have the axles!
Old 11-18-2018, 01:58 PM
MoparFanatic21
Front coil springs either will have a spacer on top of them or longer springs, back with either have a lift back or 6 springs max from the factory. Also could have a shackle flip
EDIT: Looking at your pictures it looks factory height
Old 11-18-2018, 03:51 PM
WhiteSnake91's Avatar
WhiteSnake91
WhiteSnake91 is offline
doesn't look lifted to me, just the bigger than stock tires give it a bit more height than normal
I could have sworn my old 01 3.9 ram was lifted along with having the dodge 17inch offroad version wheels, with 275-65-r17s or so tires. I had to hop up a little to get in lol. But the big tires and wheels versus stock could have just given the lift kit illusion as well.
265 16s would be for sure fine, that's what my dad runs on his stock 98 ram, I use 245 16s on my 95
Quick Reply: Is my truck lifted? Also, are my tires too big?
