Right Defrosters barley blowing air
My right defrosters are barely blowing out any air while my left ones blow out a lot. Started to notice this couple weeks ago as the right side of my windshield wouldn't defrost much. Heard could be the blend door or could be stuff in the vents. Any ideas what the problem is? Or any suggestions? Also I get warm air sometimes sorta hot air, but not as hot as it should be.
Lack of heat may be a blend door problem, or, it may be air trapped in the heater core. They are notoriously difficult to get all the air out. Your truck uses a stepper motor to control the blend door, and the little plastic coupler between the motor, and the blend door axle tends to crack apart, and you don't get full range of motion there. Easy to check, relatively.... two screws and an electrical connector. One screw toward the bulkhead is a bear to get to though.
