1986 dodge ramcharger wiring issue.
I have a 1986 ramcharger with a 318 and 727 trans. my issue is i have no headlights, the tail lights work, i remade the entire wiring harness across the front of the truck. i have tested all the fusible links and they are all getting power. the headlight switch is brand new and i put in led headlights, the passenger side marker light in the fender is not getting power, and none of the blinkers work, the right blinker on the dash stays lit up solid all the time, where should i go from here?
I tested the wires going to the headlights with a test light and they are not getting power, so that tells me that it has nothing to do with them being led lights, also since i also put in a regular bulb just to see if they would turn on and still nothing. After i made this post i went and changed all the fuses in the fuse panel, and the relays for the horn and headlights (none were popped, changed them just to get rid of the 30 year old fuses) but long story short still didn't fix my problem. i also came across some info about a body control module? i have never heard of this before, from what i understand it controls all of the lights in the truck, i was told to change it my question about that is is that the same as the ECM (computer on the inner driver side fender)?
