OBD1 5.2 Swap into 98
Old 12-14-2018, 04:07 PM
Skreelink's Avatar
Skreelink
Skreelink is offline
Default OBD1 5.2 Swap into 98
I'm thinking of buying a 1994 Dakota ext cab for the 5.2 Magnum to drop into my 1998. They're asking ~2k for it, but the engine itself was replaced by Dodge about 8 years ago and only has about 30k miles. A couple electrical gremlins (namely fuel pump works, doesn't show gas level), but about it for problems.
I know I have to swap out the sensors for OBD2 versions (crank, cam, temp, what else?) What all would be involved in converting and dropping this 5.2 into my 98 to replace my 3.9? Subsequently reversing for the 3.9 to resell or backup in the 94.
Old 12-15-2018, 09:09 AM
00t444e's Avatar
00t444e
00t444e is offline
I have been getting some info about swapping a 5.9 in to my 98 as well. From what I understand so far all the 3.9 accessories and harness will work on any year 5.2 or 5.9 Magnum, then you have to add the wires for the 2 extra injectors. The computer part is what confuses me because I am getting different answers on what will work. I have heard I can keep my 98 v6 computer and have it reprogrammed for the V8, but some say that won't work. Others say a 5.2 or 5.9 computer will work but has to be from the same year Dakota, some say any 97-99 v8 computer will work, some say it has to be for a 5.9 only, and since mine is a manual it has to be from a manual transmission truck. I emailed a tuner about this a month ago but never heard back from them. I guess it will be trial and error.
Old 12-15-2018, 09:27 AM
Received 3,164 Likes on 2,918 Posts
On the full-size trucks, the communications bus changed in 98. I don't know if the Dakota's did the same..... but.... You *should* be able to simply add the wiring for the additional injectors, and flash your existing pcm for the V-8.
Old 12-15-2018, 09:44 AM
Skreelink's Avatar
Skreelink
So the sensors and injectors, etc should all be the same? What about egr? Remove and cap?
Old 12-15-2018, 09:51 AM
Yep. EGR went away in 96.
Old 12-15-2018, 11:40 AM
Skreelink's Avatar
Skreelink
Wonder if I could leave the EGR in place, just not hookup the vacuum or electronics. Also, the exhaust should lineup correct? The manifolds should be yhr same for all magnum engines?
Old 12-15-2018, 09:57 PM
You can get a block off plate for the egr valve itself, then just need a plug for the port on the passenger exhaust manifold.
Yep, exhaust should line right up.
Quick Reply: OBD1 5.2 Swap into 98
