Removing old gasket off intake!
Well today I finally found the time to replace my plenum, I知 still waiting for the kit in the mail from Hughes though. It looks like cleaning the dang things are going to take longer than removing! I had it all apart in a hour and a half! What have you guys done to remove the old gasket? Ive always used the die grinders with the pad but always on steel!
I only used gasket maker on the 4 corners. It is different then silicone just for the fact it resists oils, chemicals, high temperature, etc just depends on which color you get. I didn't when I pulled mine too replace the one but it is recommended. Just inspect them and if they look good reuse them, can always go back later if they leak. Also make sure you use something to lube them when you put them back in, I used o ring grease
Get a small putty knife and grind a sharp edge on one side, It works well. I would stay away from anything the that rotates and flings dirt back in the engine(heads/block). Always use brake clean to clean the surface before you apply your sealant. Hope you opted for the fel pro gaskets not the ones that Hughes gives you with it.
There's a wheel out there, it's meant for stripping rust and paint, looks kinda like a sponge, about 4 inches around and has an attachment to put it in a drill. Usually about 12-15 bucks at any parts store, it will save you so much time and hassle, and it won't touch the metal. Whether it's on the intake, the plenum plate, or the heads. Takes the gasket off, but you still have a nice machined surface for your gaskets to mate to
