Strange Fuel Problem, I think.....
I have an 89 Dakota, 3.9 fuel injected and it has a weird problem. I twill start just fine in the morning when it is cold, it will start just fine when it's warmed up, but for some reason if it sits there for 10 hours when I'm at work, it doesn't want to start. It acts like it's flooded. How can a fuel injected vehicle get flooded? The other day my battery was almost drained from cranking. It finally started when I held it to the floor. I haven't had this truck long and I have other stuff to drive, I'm just looking for brainstorming right now and to learn about the fuel system on it. I'm not that good at working on fuel injection. The PO said the fuel tends to siphon back into the tank when it sits. Things are not adding up to me with this issue.
Holding the pedal on the floor will put the PCM into 'clear flood' mode, and it dramatically dials back on how much fuel it feeds. I would be tempted to plug in with a scanner that can read live data, and see what the PCM thinks engine temp is when it doesn't want to start, and compare that to actual temp.
Alright, so we have....New Plugs 7/17/2014, Computer Balancing at Ford Country 9/25/2013 (What is that? A reset?), Oh, a new fuel pump at Napa Part# P74082 4/18/2013, Fuel Vapor Hose on Supply line replaced 2/21/2013 138K miles, Fast idle solenoid replaced 10/27/2011, New passenger side Fuel Injector 10/17/2011, and that's pretty much it. When I replaced the exhaust on the truck the O2 sensor looked new. These dates are old, but it only has another 17K miles since the time of the work so I will rule out these things, not that any of it helps me with this issue. So if I were to start throwing money at it, mainly sensors, what would I be replacing? Like I say, I think sometimes it better to have a 'Fresh Start'. I don't have a code reader, I still need to get a repair manual, I might do that today. Is there a way I can pull up codes withut a code reader? Like the 3 times ignition switch trick or anything like that?
Fuel Pump may still be failing with age; if these vehicles aren't run enough, they'll have problems due to rotting from sitting still.
The repair manual you should have is the Factory Service Manual; it was printed by Bishko for Chrysler Corp, and you can sometimes find them on Ebay. (You may notice you don't drive a Chilton Dakota or a Haynes Dakota, but a Dodge Dakota ... )
And yes, the ignition switch key dance will kick out the codes.
As to your original problem - I'll lay even odds it's due to leakage of an injector flooding the intake when it's just warm enough, and overnight the gas evaporates.
(The other thing I'd definately check would be all vacuum lines in case something's opening when warm.)
RwP
Computer Balancing would probably be the wheels and tires.
RwP
RwP
RwP
RwP
