Steering wheel radio controls to '95
There was a 3rd gen thread here about radio controls on steering wheel, and I asked there that could it be possible to retrofit them to a '95. MoparFanatic21 said that I would need to swap the whole dash to accomplish that. Thought that it would be rather spendy, so I took a look on wiring such a feature on a 2001 truck. So far I found out that radio control signal goes from steering wheel to CTM via clockspring, and from there via CCD bus to a radio. Not too complicated.
So basically I would need to get them switches, clockspring, CTM and corresponding radio. And connectors for prementioned parts.
Naturally switches don't fit to a '95 steering wheel without a little fabrication. Though I could change the steering wheel all together, but not sure will the later model cruise control switches work. Or the airbag with the older collision sensors.
Question #1: Does the CTM work if there is only needed power inputs, datalink and clockspring connected?
Question #2: Is there a factory radio, that has a aux connector and RCA output? I found that cd-changer connection could be used as an aux connection. Or is there an aftermarket unit that understands the steering wheel controls?
The communications bus on the newer trucks is RADICALLY different than what is on your 95. I would seriously expect that you would need to change the entire steering column in order to utilize the more advanced clockspring. (I suspect it simply won't fit in the 95 column.)
For the cruise, so long as it is wired up correctly, and the resistance values for the various switches is the same, (maybe.....) it *might* work. If everything from the steering wheel goes thru the CTM though, likely not.
I suspect it would be a major undertaking to make it work....
I knew the difference between the data bus systems, that's why I'm thinking it as a kind of a stand alone system. Buttons, CTM, radio. Nothing else. IF the CTM works without the rest of the factory system connected.
Cruise control should work, as it doesn't go through CTM, it goes directly from clockspring to a PCM. What made me wonder is that 2001 has a cancel switch, which is not on a 1995 switch panel. Couldn't find resistance values for the cruise switches, but they are easily measured from the actual switch panel.
That's not the problem at all it's the values. If I could take a video I would of how I have them set up.
