Oil spraying on the front of the engine
I started to get a bad serpentine belt squeek today so I popped the hood and found oil spraying all over th front passenger side of the engine. I believe it is the timing chain cover, is there anyway to check this? I didn't get a picture of it but it also sprayed all over the iner fender on the passenger side. And to top it off my waterpump started leaking as soon as I got home.
On the diesel when the killer dowel pin comes out in makes a hole right there. I bought a 94 that had a window in the timing case cover and a chunk of aluminum in the oil pump and two spun mains, one rod,stuck piston and a turbo out to lunch. Someone tried to JB weld the hole shut on mine, now I know what to look for.
