2 quick questions.....
Old 01-20-2019, 03:26 PM
campermama's Avatar
campermama
campermama is offline
Default 2 quick questions.....
1 - The reservoir in the picture below...is it a brake fluid reservoir? I know the one behind it to the right is the master cylinder but what's the other one??
2 - Should I be concerned with the other picture, front diff?, Not wet or dripping but......?
Thanks in advance!!
Old 01-20-2019, 03:41 PM
The one your arrow is pointing at is the brake master cylinder, the smaller one behind it is for the clutch.
On the diff, you have a seal going bad. Nothing new under the sun there. Check the fluid level, make sure it's up to snuff, fix it when it's warmer outside.
Old 01-20-2019, 04:12 PM
campermama's Avatar
campermama
Is there another name for the seal? My manual doesn't have anything on a seal. Also, is it hard to do? Thanks!
Old 01-21-2019, 11:32 AM
jrsick's Avatar
jrsick
jrsick is offline
Pinion seal.
Is it hard? Look in your manual and youtube to see what's involved.
Most auto parts stores have the puller you'd need as part of their loaner program.
Old 01-21-2019, 11:56 AM
jkeaton is offline
Old 01-21-2019, 12:25 PM
campermama's Avatar
campermama
Originally Posted by jkeaton
Would this be the same for the front? Thanks!!
I'm also wondering how the fluid went towards the front of the diff?? How does that happen?
Old 01-21-2019, 12:42 PM
jkeaton is offline
Process is the same. And the fluid is running to the lowest spot.
Quick Reply: 2 quick questions.....
