ignition lock removel without key
Old 02-19-2019, 02:49 PM
96ram150's Avatar
96ram150
96ram150 is offline
Default ignition lock removel without key
is it possible to remove the ignition lock cylinder without the key? I need to know cause I bought my 96 without a key and I have a new lock cylinder for it
Old 02-19-2019, 04:16 PM
MoparFanatic21's Avatar
MoparFanatic21
MoparFanatic21 is offline
Could try to hammer in a screwdriver and get it to turn. If not you'll have to have a locksmith make a bump key. That's the only 2 ways I know
Old 02-19-2019, 07:49 PM
DerTruck's Avatar
DerTruck
DerTruck is offline
Drilling/grinding works too, but with an old lock try wiggling/tensioning with something resembling a key first.
Old 02-19-2019, 08:27 PM
MoparFanatic21
Also you could pick it.
Old 02-20-2019, 01:25 AM
AtomicDog's Avatar
AtomicDog
AtomicDog is online now
You may also need a replacement switch along with the new cylinder assembly. Check out the following video for the general process.
Quick Reply: ignition lock removel without key
