Help! I lost my credit card in my center console!!
Yep. Remove the console. I found this on a Charger forum. Not sure if yours is exactly like this but you get an idea of what you need to do.
REMOVAL
1.Apply the parking brake.2.Turn the ignition switch to the On position, apply the service brakes and place the gear selector lever into the Neutral position.3.Turn the ignition switch to the Off position and release the service brakes.
NOTE: For vehicles equipped with the optional Automatic Express Up power window feature, calibration of this feature is required whenever power to the door module is disrupted. A battery reconnect procedure must be performed anytime the battery has been disconnected. 4.Disconnect and isolate the battery negative cable.
5.Using a small flat bladed tool or equivalent, separate the retaining ring (1) and slide down the shifter shaft.
6.Pull up on the shifter **** (1) and remove from the shifter shaft (2).
7.Remove the mat from the cubby bin at the front of the floor console.8.Open the lid of the console rear bin and remove the mat from the rear bin.9.Remove the two screws (1) that secure the front of the console shifter bezel to the console.10.Using a trim stick unsnap the console bezel from the console 11.Remove the shifter bezel from around the gear selector lever.
12.Remove the three 8 mm bolts (2) from the rear bin that secure the console to the floor panel transmission tunnel.13.Remove the two screws (3) that secure the front of the console to the instrument panel.14.Slide the console rearward far enough to access and disconnect the jumper wire connector (4) from the accessory power outlet on the underside of the console.15.If equipped, disconnect rear heated seat connector.16.Remove the floor console from the vehicle.
REMOVAL
