3rd Gen Ram Tech2002-2008 Rams: This section is for TECHNICAL discussions only, that involve the 2002 through 2008 Rams Rams. For any non-tech discussions, please direct your attention to the "General discussion/NON-tech" sub sections.
highly doubt it as they use different frames. I will measure my 2500 spring from eye to eyelet if you must know. just cause the springs are changed...a 1500 uses a semifloating axle system...you can't load it like a full floating 2500 axle.
