Rear axle bearings
Rear axle bearings
With 300K just around the corner, I'm wondering if any of you have had to replace the rear axle bearings? (Truck is 2WD)
I'm not having any issues or sounds, just trying to get a general idea. From what I can gather, my axle bearings are lubricated by the gear oil in the diff and are not like the greased/sealed versions. Haven't had to dig into this rear end too much. I replaced the gear oil around 47K mi ago, so nearing time to do it again. If I have the diff cover off, might be a good time for bearings, if needed.
Glove box says...
DHA Torque convertor lock
DMD Axle ratio 3.55
DRB Axle rear corporate 9
Glove box says...
DMD Axle ratio 3.55
There's a lot more to replacing the bearings than pulling the cover. You'd need to pull the brakes, etc to pull the axles.
My opinion, leave them alone.
If they aren't noisy they're probably fine. As you said, they are constantly lubricated and usually, not heavily loaded.
A common sign they're going is oil around the axles or on the brake drum. It's due to seal failure from the worn bearing.
I replaced mine recently tracking down a noise (which turned out to be a transmission mount). Decently easy, though mine is a 98. Jacked up rear, removed diff cover to drain, removed tires + drums, remove screw that holds the spider gear pin, slide pin out, push axles in, remove c clips, pull axle shafts out. Commence removing and replacing bearings/seals. I didn't have to break down the brakes. Suggest one side at a time, and slide pin back in to hold gears so you don't have to remesh.
