[5th Gen : 08+]: New to us '14 RT AC issue
Hello everyone. My wife and I just bought a 2014 GC RT and although we made sure to check that everything worked, we both neglected to check the AC. DOH! Well it's not working. I don't hear the compressor clutch engaging at all. I did a little research and learned about the blend door issue but that doesn't seem to be the issue here since the temp is the same at all vent locations. Heat does work at all locations. I'm a decent wrench and know about low pressure switches, clutch relays etc but I'm checking with you guys since i'm new to this gen Caravan. Before I assume the clutch lock out is engaged due to low refrigerant and a leak, are there any known issues with the AC not engaging on this year? I appreciate any input. It's the automatic HVAC system with rear air and 107K. Oh, one more thing. Is there a self-diagnostic for the HVAC panel that anyone knows of? Thanks.
