New here and and about to break my Windows on my 97 Dodge Ram 1500
The ABS, Brake and another light are on constantly. No A/C, heat, defrost or power windows. Can't figure out what the problem is. I checked all the wires and haven't found any damage. Checked/replaced fuses. It's getting hot and I need my windows to work. A/C worked before this happened.
Do you have power for the windows at the switch? (they are on an automatic circuit breaker.)
No power to either. I moved my steering wheel down and they went off for second and then came back on..I remember watching a video on YouTube that the mechanic said it was a wire that pulled out of the box. Didn't show where the box was located or how he repaired the wire.
That would be in the steering column itself. Gotta pull the covers off, and check on the back of the ignition switch, etc. I think the clamshells are held together with 'security torx' screws though.... (torx with a post in the center.)
Ok. Will look into this in the next couple days and let you know what I find. I have work this weekend. Tysm for all the information😊
