Dodge Stealth The car that can still draw looks from auto enthusiasts everywhere, the Dodge Stealth. From the Naturally Aspirated version to the Twin Turbo, the Dodge Stealth has a little something for everyone.
Dodge Stealth 93 won't shift when running
Old 04-19-2019, 05:47 PM
Juan H's Avatar
Juan H
Juan H is offline
Default Dodge Stealth 93 won't shift when running
Dodge Stealth 93 twin turbo all wheel drive. It wouldn't shift so I replaced the clutch, throw out bearing, master clutch cylinder and slay cylinder. Still doing the same thing. Help! Grateful to all that can help me figure it out. Sincerely, Juan H.
Old 04-19-2019, 06:27 PM
jkeaton is online now
So it’s stuck in gear? Shift linkage broke?
Old 04-19-2019, 06:44 PM
Juan H's Avatar
Juan H
Juan H is offline
When the car is off I can put it in any gear and when off I put in 2nd it will start and drive but won't shift any more gears. I can turn the car off and put it in 1st and it will drive but you can't shift out of it.
Old 04-19-2019, 07:38 PM
Received 3,164 Likes on 2,918 Posts
When you crank the engine, does the car start moving, or feel like it wants to?
When you try and shift, is it hard to get out of gear? Into the next? Both? Does it grind??
Old 04-19-2019, 07:57 PM
Juan H's Avatar
Juan H
Juan H is offline
It moves and drives but I cannot shift out of gear while driving . I will not force it to make it grind.
Old 04-19-2019, 08:33 PM
It won't come OUT of gear??? Hhhmmm, now that is an odd one...... I don't think that's a clutch problem though..... May be time to pull the trans, and have a look inside.
Old 04-19-2019, 08:37 PM
Juan H's Avatar
Juan H
Juan H is offline
I appreciate your input. Have a blessed Easter
Old 04-19-2019, 09:20 PM
You too. Hope the weather is nice for ya. I know it's gonna suck here.... (which, according to my Grandma, it will rain for seven more Sundays....... Certainly hope not.....)
Quick Reply: Dodge Stealth 93 won't shift when running
