Brake light & parking light wiring problm
On my 91.5 W250 Cummins I have a issue. When I apply the brakes the rear brake lights work fine however the parking lights up front will slightly glow as well. Any ideas what might be the problem.
I have cleaned & or replaced grounds, pulled the fuse box to see if are any wires touching, removed the pig tail on the firewall where all the main wiring goes. Replaced the multi switch (turn signal lever housing). All looks good there too. Found nothing wrong under the dash as well. Are there any relays in line from the brake light switch that may cause this problem? I’ve been dealing with this problem for a couple of years & found nothing out.
thank you for your help. If you come up with anything else that may be the problem please contact me.
Doug
If you think of anything else please contact me.
doug
Thanks for the feedback.
Doug
