'95 2WD - Electrical Problems
One thing a lot of people miss on the radios - did you connect the ground wire?
There's no negative return on the wiring harness; our radios use a ground wire to a dash brace.
Next check the connection AT the cross brace; if it's been loose at all, it can corrode enough to cause a no-connection problem.
(Hence the "Check Grounds").
Be sure to pull the factory service manual PDF down from the FAQ; you can use that to back trace the wiring to find out where it's not working.
RwP
RwP
