Is this where I should refill my freon?
Old 05-18-2019, 07:26 PM
Alex Medeiros's Avatar
Alex Medeiros
Alex Medeiros is offline
Lightbulb Is this where I should refill my freon?
Hey everyone, I was just wondering if this is the right place to add freon as I think mine might be low. Thanks!
Old 05-19-2019, 06:50 AM
fj5gtx's Avatar
fj5gtx
fj5gtx is offline
I added some freon to my 04 1500, I do not remember it being that close to the firewall.
Old 05-19-2019, 08:40 AM
jkeaton is offline
R134 refrigerant. Not freon. Freon was phased out years ago. There should be 2 ports. The smaller of the 2 is where you refill.
Firefighter555 (06-23-2019)
Old 05-19-2019, 10:22 AM
Alex Medeiros
Where did you fill up you refrigerant at? I would assume it's the low pressure line right?
Old 05-19-2019, 10:31 AM
primem's Avatar
primem
primem is offline
that is the low pressure line....low pressure side has the small fitting but the big hose. most aftermarket refill kits fill on the low side. you can't mix it up as the low and high side connectors are different...it won't connect to the wrong line.
vacuum the system, add 1 oz of pag oil, charge the system...weight your cans before and after...weight is the only accurate charge method. static pressure is temp dependant.
if your missing caps...get them. they keep dirt out and are a secondary seal.
Old 05-19-2019, 10:57 AM
Alex Medeiros
So was my picture the correct spot to fill it up? I didn't see the cap which threw me off.
Old 06-10-2019, 08:03 PM
ol' grouch's Avatar
ol' grouch
ol' grouch is offline
I had to replace the high side service port on my Cadillac Escalade today. Attached is the photo I took to show the counter person at the parts store. Keep in mind, this is NOT a Dodge. It does show the high and low side connectors. The low side has the cap still on. On my '02, the low side port is near the receiver/dryer (big black round thing near the firewall). This is the only one that aftermarket charging tools will fit.
Old 06-10-2019, 09:55 PM
Alex Medeiros
Too bad I learned this now, I sold my truck a couple of weeks ago
Old 06-11-2019, 08:13 AM
ol' grouch's Avatar
ol' grouch
Alas, I haven't been here for a while. I had abdominal surgery and am just now getting around and feeling human. (Hint, getting old is NOT for wimps!) One thing about the R-134 systems is the fitting are different sizes so you can't hook them up backwards.All the recharge kits on the arket use the low side port, regardless of what vehicle you have.
Old 06-11-2019, 08:15 AM
ZEN357's Avatar
ZEN357
ZEN357 is offline
Two different size valves. The refrigerant kit will only, fit on I believe the smaller of the two valves.
Quick Reply: Is this where I should refill my freon?
