Does your AC do this?
So ever since I've had this truck, the AC control has always been sketchy. When I turn the temp **** to max cold, the AC is very cold, however just a few clicks warmer and the cold air stops blowing just about altogether. Even readjusting just just under max cold, does nothing sometimes. I have to max it out to get cold air. Been doing this many years and does not work this way with the heat. Wondering if this is a controller issue or low refrigerant. Been this way many years though.
Anyone else seeing this?
I pulled the fan out years ago when troubleshooting the low airflow issue. Everything I could see at the time, was working fine. I had pics, but the hosting site went belly up. My truck doesn't have a cabin air filter. Does yours?
My 01 didn't have an air filter and neither did my 03. Both of them didn't blow very hard compared to most vehicles, but still cooled and heated fine surprisingly.
I would blame the blend door as well. Blending problems seem to come up fairly frequently.
But if it is a controller let us know! I would have to try it on my truck too!
Will do. Should be less than 20 bucks at pullapart. Thanks!
Maybe 2005 and up? I know this generation doesn't.
Yeah. It still cools and heats well enough though. Actually, the heat will roast me. Not sure I can get to a blend door without pulling the dash (which I won't be doing, LOL).
Edit: Accord to comments from this guy with a Durango, I might be able to get to the mechanism without pulling it.
Just getting to it and effecting any fixes are two different matters though.
Thanks for the pic. I've yet to get a true service manual for the Dak. The ones on the site have turned out to be for the Ram (even though they were named Dakota) and I'm too cheap to pay for one. Funny story.... early on, I used that Ram 1500 service manual for a long time thinking it was actually for the Dak. I sorta wondered why things were different, but was always able to fill in the blanks. It was when I actually looked at the diagrams of the front end, that it finally dawned on me. LOL
