1990 Dodge Dakota LE / water in floorboard
Hi,
I inherited my granddad's 1990 dakota LE. 167000ish miles. Runs great for what it is. However, it does have some issues that has be debating fixing versus selling.
The biggest issue is that water pools in the driver's side floorboard when it rains. I've tried time and again to get it to recreate with the hose and it won't. No wet spots higher than the bottom of the gas pedal. I don't see water leaking in via the firewall or higher.
My best guess, though I can't get it to reproduce is water seeping in at the bottom of the frame. The plastic piece that holds down the upholstery is dry and cracked.
Thoughts?
Thoughts?
1990 still has the ram air vent; I'd pull the cowl cover and clean out all the leaves that have probably collected in the cowl, including down into the fender, to clean out the ram vent.
That's one possible point; takes enough water coming in to back up into the ram vent when the drain is partially plugged with leaves.
Your other possible from where I'm sitting would be bad door gaskets; either door frame to door or window runs.
RwP
RwP
I second what Ralph says. This is an issue on Ram50's and it is solved by removing the screws at the bottom of the fender next to the door and cleaning out the gunk. That is the designed drain from the cowl. IDK where the designed drain from the cowl is on Dakota's.but it seems reasonable it would be the same.
Finally getting around to this. I have the cowl off but I’m confused as to where “down to the fender” would be.
RwP
RwP
Go to the outside edge with a fish rod of some kind (they actually sell flexible cleaning brushes for things like cleaning lint from exhaust hoses from dryers), and follow the path down.
RwP
