Front axle nut
Old 06-10-2019, 12:47 AM
biziedizie's Avatar
biziedizie
biziedizie is offline
Default Front axle nut
1997 Dakota 4x4 front axle nut. Besides an impact is there another way of getting the nut off? Also am I correct that the torque should be 185lbs? I believe that's what I read but I'm not 100%. Thanks
Old 06-10-2019, 07:19 AM
Skreelink's Avatar
Skreelink
Skreelink is offline
I just used a 2 foot breaker bar on my 98 to remove. Also, 185 ftlb is correct. They're nylon insert nuts, so make sure to get new ones with the hubs. Though, this was on a rwd.
Old 06-10-2019, 10:58 AM
magnethead's Avatar
magnethead
magnethead is offline
Not sure if 2wd and 4wd are the same. As far as removal, I used a 3 ft 3/4 drive breaker bar, climbed up on it, and jumped until it broke loose. (That's about 600 ft-lb of breaking torque)
Old 06-10-2019, 11:13 AM
Skreelink's Avatar
Skreelink
I expected to hear magnethead say "I backed the dragster up and attached it to the wheel, and simply mashed the gas on the dragster to spin the nut off."
Old 06-10-2019, 11:18 AM
magnethead's Avatar
magnethead
On a related note, have you seen Milwaukee's new 1" drive electric impact? It's like the machine gun of impact guns.
Old 06-10-2019, 11:23 AM
Skreelink's Avatar
Skreelink
Can't imagine the battery lasts too long on it, but it's likely a beast.
Old 06-12-2019, 02:33 AM
biziedizie's Avatar
biziedizie
I ended up sticking a long pipe on the ratchet and it finally came off. The guy at the parts store said that the left and the right side shafts are the same but I've read differently online. Who's right the guy who does it for a living or people who own online?
Old 06-12-2019, 12:47 PM
magnethead's Avatar
magnethead
Check what RockAuto lists, but i'm fairly sure they are different.
Old 06-13-2019, 07:37 PM
biziedizie's Avatar
biziedizie
Will do, thanks
Old 06-16-2019, 04:56 PM
XSubaruJeepDude's Avatar
XSubaruJeepDude
XSubaruJeepDude is offline
Very informative video and channel
Leverage is your friend.
Quick Reply: Front axle nut
