Stand alone electronic ignition
Old 06-12-2019, 12:40 PM
4990Ram's Avatar
4990Ram
4990Ram is offline
Default Stand alone electronic ignition
Computer is shot. Shop told me it couldn't be fixed. No spark at plugs. Spark at coil.
Soooo, I think my only option is to covert to the older style electronic ignition.
Anyone done this? Thoughts?
'90 D250 auto fed emissions engine code Z.
Old 06-12-2019, 01:55 PM
Erm, if the coil is firing, but not the plugs, then you have a wire, distributor cap, or rotor issue. The ECM is doing it's job.
Old 06-12-2019, 01:58 PM
4990Ram's Avatar
4990Ram
4990Ram is offline
New wires, cap and rotor.
According to the FSM my ECM is bad.
Sent it out to be repaired and it can't be fixed.
Old 06-12-2019, 01:59 PM
If the coil is firing, the ecm is doing its job. If the spark isn't getting to the plugs, the ECM has nothing to do with that. It fires the coil. That's it.
Old 06-12-2019, 06:00 PM
crazzywolfie's Avatar
crazzywolfie
crazzywolfie is offline
sounds like you need a new shop if you got spark at the coil but none at the plugs and they can't fix it.
Old 06-12-2019, 06:32 PM
4990Ram's Avatar
4990Ram
4990Ram is offline
It's not at a shop. I followed the trouble shooting sequence in the FSM.
Then sent the ECM to a company in FL. I got an email from them yesterday
saying the ECM can't be repaired.
The FSM says the ECM is/was bad.
I'm now trying to find a way to get the truck running.
I was told swapping to the old style ignition was the way to go.
Old 06-12-2019, 07:00 PM
Moparite's Avatar
Moparite
Moparite is offline
How about getting another ECM IF it is indeed bad? You can use a stand alone ignition but what about throttle body injection? Carb swap?
Old 06-12-2019, 10:14 PM
crazzywolfie
you need more than a ignition to run a 88 and newer truck. what about CARDONE798936?
Old 06-13-2019, 12:25 AM
4990Ram's Avatar
4990Ram
4990Ram is offline
79-8936 is for '91 or '92.
I thought they were year specific?
Old 06-13-2019, 12:30 AM
crazzywolfie
nothing really changed that much. TBI is TBI. it wouldn't surprise me if a 318 or 239 computer would work since at the end of the day it is just 2 injectors firing fuel into the engine and the o2 sensor correcting as needed once warm enough.
Quick Reply: Stand alone electronic ignition
