A/C question
Old 06-21-2019, 01:33 PM
moldmaker70's Avatar
moldmaker70
moldmaker70 is offline
Default A/C question
So yesterday my a/c decided to not blow cold at all. Figuring that all it needed was a shot of freon since the clutch was coming on and didn't shut off. I hooked up the bottle and the gauge is reading in the red between 60 and 150. Where should I start? I have never done anything to the system except a little freon once a summer. Thanks for your help.
Old 06-21-2019, 02:11 PM
jrsick's Avatar
jrsick
jrsick is offline
Is your radiator condenser fan coming on?
Do you hear a click when the relay turns on the compressor?
Your gauge reads in the red, is that very low or very high on your gauge?
Old 06-21-2019, 04:54 PM
moldmaker70
Yes, everything seems to come on like it should. I have one of those gauges that come on the freon can. It reads that it has plenty of freon as I understand it.
Old 06-21-2019, 08:46 PM
jrsick's Avatar
jrsick
jrsick is offline
Generally a red reading on any gauge is bad.
You will not get cool air if the ac system is overcharged.
Old 06-21-2019, 09:01 PM
primem's Avatar
primem
primem is offline
a low charge symptom is short cycling. compressor not shutting off is not a low charge symptom.
feel the metal hoses as they near the firewall...the large diameter hose/low pressure side should be cold and the high side hose should be hot.
-verify the temp blend doors in the dash are moving from hot to cold.
Old 06-21-2019, 10:02 PM
moldmaker70
I tried turning the temp and it's so hot I cannot tell if it is changing temp or not. Also i guess that o better get some of that freon out of the system.
Old 06-22-2019, 10:22 AM
primem's Avatar
primem
primem is offline
feel the lines like I suggested...if they are hot and cold...the problem is more likely in the blend doors. if they are near the same temp...its an ac performance problem not the doors
Old 06-22-2019, 10:45 AM
66three83's Avatar
66three83
66three83 is offline
Condenser fan.
Old 06-22-2019, 04:43 PM
jrsick's Avatar
jrsick
jrsick is offline
I have two of those a/c Freon gauges from different manufacturers. Being in red on both of them is dangerous and in "alert" range.
Is it possible that you overcharged your a/c system?
Your Freon level may have been fine, and actual problem was something else like blend door, condenser fan, or faulty relay
Old 06-22-2019, 07:10 PM
moldmaker70
Both lines at the firewall are the same temp to the touch.
Quick Reply: A/C question
