Spool/locker 9.25
Spool/locker 9.25
91 D150 360 magnum swap, 36RH 2400 stall.
I'm gonna be putting in a spool or a locker. Is any brand better than the other?? Rebuild kits availability?? Ease of rebuilding? Dependability?Think I would rather go with a spool but I can't find them for the 9.25. Dana 60/44 and the 8.75 is all I can find them for. I've checked summit, jegs. Would a d44 swap be easier??
rebeltaz83 (06-23-2019)
are you re-gearing or anything at the same time? might be worth looking into a crush sleeve eliminator kit. if you are not re-gearing a lunchbox locker would likely be the cheapest and easiest route. you can install one in your axle in a matter of hours. @SixGunRichard has one in his truck and it always looks like it performs pretty good. i don't know what brand he used tho.
Any suggestions on brand??
Summit has a Dana Spicer carrier for $310
Richmond gears 4.10 for $150
Plus the installation kit what ever that runs.
Little pricey, about $580 without installation parts, and gears..........I think I'll keep scouring Craigslist, something will pop up eventually. How much of a pain is it doing an 8.75 swap? Or a newer 9.25 from a mid 90s up 1/2 ton w/disc brakes? And that is a future mod, 4 wheel disc brakes. Just gathering info. Nothing is set in stone.
