LSD recommendation for 9.25 diff
Hi,
I purchased a 96 B2500 Van (I know this is the truck forum, but I figure not too many people are doing this kind of stuff to vans so I may get a bit more responses) that I'm lifting and may 4x4 later on. That's a whole other story, if it happens.
I'm wondering if anyone has recommendations on which LSD would be a good match for my use which will be light off roading. I thought about a locker, but being that it's either locked, spool or open I'm concerned about the performance on snow/ice and rain vs the LSD which I think might be more versatile in more conditions since realistically it will spend more time on the street than off.
What are your thoughts? Would like to keep it under/around $500 as well.
Thanks!
Thanks!
Thanks. Looks like the Truetrac could be had for $560-580 so that's not too far off.
https://www.justdifferentials.com/TT.../tt913a368.htm
Thanks!
Thanks!
Here is a less expensive quality positrac/limited slip. I do like the Trutrack better due to gears that won't wear instead of clutchpack type LS/Posi, but they can be rebuilt about 200,000 mi from new.
https://www.ebay.com/itm/Yukon-9-25-...UAAOSwJtdaDzG4
