1989 b350 - gauge cluster issue
Be careful when removing the instrument cluster, you need to remove the knee panel below the steering column to disconnect a little cable between the shifter linkage on the column and the gear shift indicator. If you pull the instrument cluster with this attached the little arrow will likely break off when the spring retracts the cable. Then you have to crazy glue the arrow back on...
I don't recall how the lighting works back there, our cluster has been rebuilt twice so they probably changed the bulbs each time.
twas a fuse
the manual was helpful in determing which fuse it should be (fuse 5). Never seen a fuse box with just 10 fuses before!
I thought by testing the fuses with a continuity tester, I could tell if a fuse was bad, however my meter was showing the fuse was OK, but when I removed it, it fell apart. Replacing it with a new Glass fuse has fixed the problem
thanks for note about removing cluster.
