What lube for temp control internals
on
I found the temp control buttons weren't working so set out to fix the problem. As expected the rear cover plate of the control box has broken away from constant pushing of the controls. Worse still 3 of the 4 slider thingys fell on the floor as I removed the controller.
I managed to put them all back in place and tested the controls, turns out I must have put them in **** about as the fan now starts up when I hit the off button. But should be able to fix that by dissasembling and doing a shuffle.
But just wondering what lube to use on the 4 sliders that rub against each other. The action is really stiff and would like it to work a lot smoother.
Any ideas ??
Any ideas ??
i could be wrong but i almost feel like you probably need a dry lube of some sort to lube all the internal parts since you don't want anything blocking any of the vacuum passages or drying up and causing it to not work. hopefully you can fix it because even where those trucks were more common that is usually a bit trickier part to find in good working condition. they like to melt as they get older.
on
Well, I puled the unit back out today to refit the sliders in the correct orientation. Started searching my shelves for some sort of lube and found some O Ring Lubricant which sounded OK. Tried that but failed, it made the action stiffer than is was with 30 plus year old grease in it.
Oh well, back to the drawing board as they say
