04 Dodge Ram Powersteering pump replaced 4 months ago failing again
Did you flush it really well? Crap from the old pump could have gotten into the steering rack and chewed the new pump up. If I have any doubts, I add a filter in the return line for the pump. You may end up replacing the rack too.
Thank you for responding
i have 2500 5.7 right after installing the new pump I flush it with 2 -3 quarts. Made sure it didn’t run dry. The guy from auto parts store told my wife to run regular power steering fluid not the plus 4. Didn’t sound right so I went back and got the plus 4 but I flushed it with the powersteering fluid.
I also replaced the oil cooler with aftermarket one.
steering is fine . Only thing I notice is I still hear like that whining sound as if the pump was low or going bad. Its not loud or anything.And now that I remember the one I put in 4 months ago was doing the same thing. So somethings not right .could it be the steering rack or gear
i pulled the return line and cranked the motor I made sure to keep it full. I thought that was why it was making that noise. I checked for air leaks the first time and this time i can’t find any. I am going to look again tomorrow.
49ersrule62 (08-05-2019)
