Dealer suggesting replace engine
Old 07-23-2019, 12:04 PM
Jim dove's Avatar
Jim dove
Jim dove is offline
Default Dealer suggesting replace engine
2014 Ram 1500. 112K miles, 5.7 L. Driving along and engine started missing, then ETC message appeared and check engine light came on. Broke down completely right in front of the dealer. Dealer did a diagnostic and is recommending replacing the engine because it is misfiring so much. Gave an estimated cost of 10K. I called Chrysler to open a case to see about getting help wit the cost. Any suggestions?
Old 07-23-2019, 12:13 PM
Think I would want to know WHY it is missing..... If it is a component failure of some sort, which component? If the cam get wiped out, I could see it...... as just replacing it won't remove all the crap it is circulated thru the engine.
Old 07-23-2019, 12:44 PM
Jim dove's Avatar
Jim dove
Jim dove is offline
Thanks, they want to charge me $1200 just to tear it down to find out what is wroing.
Old 07-23-2019, 03:08 PM
TrueDogman's Avatar
TrueDogman
TrueDogman is offline
But is it actually an internal engine part causing the poor running or is it an external part like electrical sensors, fuel injectors etc. You need to be given more information as to diagnosis
Old 07-23-2019, 03:22 PM
Jim dove's Avatar
Jim dove
Jim dove is offline
That is a good question, will try to find out. Thanks
Quick Reply: Dealer suggesting replace engine
