Engine shudders. Cyl8 mf rough idle, no oil consumption
1998 dodge ram 2500 5.9l gas.. cylinder 8 misfire, runs very rough, newish cap and rotors, shudders and hesitates when accelerating, absolutely doesn't like hills, terrible fuel economy... I keep wanting to think it's the plenium gasket or whatever but I'm not loosing any oil? About 2000 miles since last oil change and it's still full.. do you think it's the plenium, truck has 172k miles
Need to have a look down in there, see what you see. I expect to see SOME oil in there, just from the PCV system. That should be a spray like pattern, if oil is pooling, that's an entirely different kettle o' fish.
What plugs in there? How old are your O2 sensors? Getting any codes? Flashing check engine lite?? How are the plug wires? Probably wouldn't hurt to check fuel pressure as well...
Would that work for fuel pressure tester?
Tests output pressure to 10 PSI
https://www.harborfreight.com/fuel-i...ter-58760.html
As for the plenum I look at it like this, You have a known problem area. Either fix it now or fix it later.
NO! Not for your vehicle.
This is for carbureted vehicles NOT efi. You need one that will go past 50 psi like this one.
