Air Bag Light, ABS Light, Brake Light, No Speedo.
Old 09-03-2024, 08:23 PM
Bays070's Avatar
Bays070
Bays070 is offline
Exclamation Air Bag Light, ABS Light, Brake Light, No Speedo.
I am having issues narrowing down my electrical issue. I have no power to fuse 52 the front airbag fuse. And I believe that it causing my issues. I allready changed the PDM out with a new one and i still have the same issues. Also fixed some broken wires as well. HELP, i dont know where to look next.
Old 09-03-2024, 08:27 PM
Received 3,380 Likes on 3,120 Posts
Need to know what you are driving......
Old 09-03-2024, 08:32 PM
Bays070's Avatar
Bays070
Bays070 is offline
My fault Im new i added it to my profile but it didnt to the thread, Its a 2003 dodge 2500 5.9l cummins
Old 09-03-2024, 08:34 PM
Bays070's Avatar
Bays070
Bays070 is offline
If I put power to the number 52 fuse all the lights go off. I Didnt drive it like that so im not sure on the speedo.
Old 09-03-2024, 08:41 PM
That fuse gets power from the ignition switch. Orange wire, pin 14 on the ignition switch connector, but, that portion of the switch gets ITS power from fuse 3 in the PDC, 30 amp fuse.
Old 09-03-2024, 08:51 PM
Bays070's Avatar
Bays070
Bays070 is offline
I changed the ignition, and didn't notice anything bad with the wiring going to it. I just checked fuse 3 and its good as well.
Old 09-03-2024, 08:53 PM
Are you getting power at pin 14 on the ignition switch with the key on?
Old 09-03-2024, 08:55 PM
Bays070's Avatar
Bays070
Bays070 is offline
ill have to pull it apart and double check in the morning, Ill let you know. Thanks
Old Yesterday, 02:36 PM
Bays070's Avatar
Bays070
Bays070 is offline
Sorry for the Long wait. Life tends to get in the way of projects. I have no power at the orange wire at the ignition switch
Old Yesterday, 03:54 PM
Kinda lost track of where I was going with this.... but, all your issues tie back to the speedo, find out why that isn't working, and everything else should follow. I have wiring diagrams, but, not a service manual, so I am not sure where it gets its signal from for the speedo, one of the wheel speed sensors, but, which one? If you have a scanner that can read live data, (ABS system), see if you are getting rational readings from the sensors.
Quick Reply: Air Bag Light, ABS Light, Brake Light, No Speedo.
