Steering me right
Old Jun 8, 2026 | 09:11 AM
moorglademover's Avatar
moorglademover
Default Steering me right
Does anyone know if there is two different idler arms for a 1999 Ram van 2500? Build sheet indicates 4000 lb axle. The ones I ordered are as sloppy as the old set, but there isn't a heavy duty listing anywhere I look.
I would definitely appreciate any thoughts on this problem.
Old Jun 8, 2026 | 11:38 AM
1998DodgeRamVanCamper's Avatar
I don't know if the idler arm is different for the 4000lb front axle, but I do know that all of these part numbers are correct for 4000lb front axle as I have purchased and installed these.
So, I know that the
MOOG K7106 MOOG K7106
is correct for your van.
Which part number did you purchase?
Part # Qty Each Total
Front Suspension
MOOG ES2147RL Steering Tie Rod End MOOG ES2147RL Steering Tie Rod End
2 $41.34 $82.68
MOOG DS1011 Tie Rod End MOOG DS1011 Tie Rod End
1 $61.29 $61.29
MOOG DS1010 Tie Rod End MOOG DS1010 Tie Rod End
1 $76.03 $76.03
MOOG ES362S Steering Tie Rod End Adjusting Sleeve MOOG ES362S Steering Tie Rod End Adjusting Sleeve
2 $12.04 $24.08
MOOG DS1414 Steering Drag Link MOOG DS1414 Steering Drag Link
1 $69.56 $69.56
Moog K7090 Strut Rod Bushing Kit Moog K7090 Strut Rod Bushing Kit
1 $23.29 $23.29
MOOG K7096 Suspension Stabilizer Bar Bushing Kit MOOG K7096 Suspension Stabilizer Bar Bushing Kit
1 $8.64 $8.64
Moog K700531 Stabilizer Bar Link Kit Moog K700531 Stabilizer Bar Link Kit
2 $7.29 $14.58
MOOG K7106 Steering Idler Arm MOOG K7106 Steering Idler Arm
2 $62.43 $124.86
MOOG K160037 Coil Spring Insulator MOOG K160037 Coil Spring Insulator
2 $15.13 $30.26
MOOG RK620369 Suspension Control Arm and Ball Joint Assembly front left upper MOOG RK620369 Suspension Control Arm and Ball Joint Assembly front left upper
1 $91.51 $91.51
MOOG RK620370 Suspension Control Arm and Ball Joint Assembly front right upper MOOG RK620370 Suspension Control Arm and Ball Joint Assembly front right upper
1 $94.77 $94.77
MOOG K7053T Front Lower Suspension Ball Joint MOOG K7053T Front Lower Suspension Ball Joint
2 $29.61 $59.22
MOOG K7117 Suspension Control Arm Bushing MOOG K7117 Suspension Control Arm Bushing
2 $16.46 $32.92
Total $793.69
Shocks
Bilstein B6 Shocks 24-184632 Bilstein B6 Shocks 24-184632
2 $128.00 $256.00
Bilstein 24-184670 B6 4600 Series Set of 2 Rear Monotube Replacement Gas Charged Shock Absorbers Bilstein 24-184670 B6 4600 Series Set of 2 Rear Monotube Replacement Gas Charged Shock Absorbers
1 $211.90 $211.90
Old Jun 9, 2026 | 10:29 AM
moorglademover
I ordered Ultra Power K7106 idler arms from Rock Auto. That Moog part number was on the list, so assuming they are compatible. These are very loose and can be rocked up and down in frame. Going to look at it again tonight.
I appreciate your help and your parts list to reference.
