Dodge Spirit Blowing defrost and floor only
Still fixing this. I got under the seat and found the actuators for the floor and panel near the steering column. I am able to manipulate one actuator and get some air to go through the panel vents but returns to the normal position. I am looking at the vacuum tubes but I see no cracks or leaks to include the tube going from the engine compartment through the firewall (which I located coming in under the steering column). The vacuum hose leading to the actuators all seem fine and connected. I created a smoke machine with a jar, mineral oil, and a soldering iron. I have not really got it to work well but I can generate smoke. Anyone have any suggestions? I am still not getting pressure and am looking for the vacuum reservoir and one way check valve.
