1995-2000 Dodge Avenger The Dodge Avenger had smooth styling in addition to solid craftmanship. To this day you can find Dodge Avenger enthusiasts proud to show of their gems.
Old 08-05-2015, 12:24 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: 4WD
Print Wikipost
Ball joint recall info
Old 11-16-2011, 09:08 PM
bad venge's Avatar
bad venge
bad venge is offline
Section Moderator
Dodge Forum Moderator
http://www.dsmtuners.com/forums/hand...-question.html
you can order thes kits for $116/$180 for the kit
  #32
Old 12-23-2011, 11:24 PM
riggsb1's Avatar
riggsb1
riggsb1 is offline
I have a 95 Avenger. I just got it on November 19th. I know those parts have to be replaced but with it being so long after the recall will they still replace them? I'm pretty sure that is what's causing the popping noise when I hit a bump. I looked on the Dodge website and entered my VIN and it says there are no recalls for my car. Any help would be great.
  #33
Old 12-24-2011, 09:49 AM
bad venge's Avatar
bad venge
Section Moderator
Have you READ the thread .... It gives the 800# CALL them and check , Some will call and get them covered others will not. seems the more you complain the more you might get them covered. I've had two sets replaced no trouble. Canada appears to do it once and thats it.I think the most I heard of was 6 sets replaced
Remember you are calling about a 16 year old car with likely 100k miles+ the chances that they will not cover are pretty good
There is one arm recalled the other is NOT I also listed the part for the complete kit to rebuild the entire front incase they are not covered
  #34
Old 12-24-2011, 06:04 PM
riggsb1's Avatar
riggsb1
riggsb1 is offline
OK, thanks. Also, I have a oil leak, it's the front seal. How do I change it?
  #35
Old 10-14-2014, 09:49 PM
eishiba's Avatar
eishiba
eishiba is offline
Would this be why my 98, every time I hit a bump, I can hear a rattle. I know this isn't what it ACTUALLY wrong but it sounds like a washer rattling loosely very loudly. Its kind of a high sound. It just sounds like everything is clunking around. Im not sure if its the front or rear. I just bought the car.
  #36
Old 03-09-2018, 11:39 PM
hoangkhanh's Avatar
hoangkhanh
hoangkhanh is offline
Thank you for the information you shared. It is very helpful to me
Quick Reply: Ball joint recall info
