Passenger window goes down but won't go up
Old 08-02-2013, 09:07 PM
that_guy's Avatar
that_guy
that_guy is offline
If its just that door is say its probably that switch, but could possibly be drivers door switches.
Your 04 Durango is a 2nd gen, so you should post your question in that section son you can get a better answer.
  #42
Old 05-19-2019, 08:12 PM
Blake Griffin's Avatar
Blake Griffin
Blake Griffin is offline
Default Dir
Originally Posted by IndyDurango
Greg,
With your quote above, I would say the window motor is fine. My bet is on an electrical gremlin. On rare occasion, my passenger side window doesn't respond to either side's window control. Just a fluke. I shut down, fiddle here and faddle there and everything is back and working fine. Dunno. In 8 years, I would say it has occurred 4 times or so.
IndyDurango
Durango windows
I am experience the same problem with back door on driving side. I discovered that the voltage on up is there but not on down. I tried cleaning the contacts on both switches, but still have the problem. I put the regulator back in and jumped 12 volts to raise the window. Then I unplugged it. I think it's a circuit board problem on the driver door controller..
Quick Reply: Passenger window goes down but won't go up
