HID Fog Lights
Old 12-18-2012, 02:54 PM
jtracing1's Avatar
jtracing1
jtracing1 is offline
Default HID Fog Lights
Has anyone tried or have any experience with putting an HID kit in the Stock Fog Light Housing. I know HID's in the headlight housing (non-Projector) causes a lot of glare and light scatter from what I have read. However, since the fogs are lower and have a smaller housing, I was curious if anyone has feedback on how well this works. I was thinking of putting true projectors with HID's for my regular lights and also installing HID fogs. Thanks.
Old 12-18-2012, 05:33 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
from what i have gathered talking to friends (off the forum) HIDs in the fog create a major glare issue for both you and other drivers in anything except perfectly clear weather
Old 12-18-2012, 06:30 PM
that_guy's Avatar
that_guy
that_guy is offline
they'll create a ridiculous amount of glare even in clear weather too, not to mention they won't serve their intended purpose anymore either.
I also wanted to add that hids aren't that bad in our oem headlights. Obviously they won't be nearly as good as hid projectors, but they're definitely better than halogens. There is fairly minimal increased glare also. Here are some comparison pictures I found of halogens vs hids in our oem housings.
Halogens:
HIDs:
Old 12-18-2012, 08:03 PM
lvphotos's Avatar
lvphotos
lvphotos is offline
I don't know about glare but they hit the road signs pretty good. I do have them down a bit since they are about stock headlight height. I gave up on the HID in the main housings. I got them sitting in the garage. Bright but too much vibration and the bs "high beam" that just moves the bulb. Then to do it right you need to add a fake load. Stuff gets hot enough to melt the other housings I got tired of stoping to make sure the crap was not burning through something. Just run high beams! Seams to be a new trend.
I got the pure white the main are white but the same bulb for fogs has a lil blueish tint.
Old 12-18-2012, 08:05 PM
that_guy's Avatar
that_guy
that_guy is offline
If they hit road signs they're glaring into other drivers' eyes
Old 12-26-2012, 04:23 PM
994x4rango's Avatar
994x4rango
994x4rango is offline
New Member
I have 5k HID's in my fogs and love them. They hit the road great and I have them adjusted correctly. Name:  IMG_20121031_201830.jpg
Old 12-26-2012, 04:34 PM
that_guy's Avatar
that_guy
that_guy is offline
Those are really bad. All they're doing is blinding other drivers with all that glare, not to mention they won't be useful in the fog anymore since they're throwing light all over the place instead of just under the fog.
Quick Reply: HID Fog Lights
