2002 D 5.9L no start
Old 07-27-2015, 12:29 PM
lubeman1's Avatar
lubeman1
lubeman1 is offline
Default 2002 D 5.9L no start
Hey guys, This morning I had to run out early before work fired up the D and drove about five minutes to the wife's truck to grab some stuff. I threw it in park still running, grab the stuff and when I went to leave it stumbled and stalled.
I tried immediately to re-start and nothing just crank and crank, let it sit for 5 minutes or so it tried to start briefly then nothing did that twice.
I had to leave it and took the wife's truck back to work so I couldn't check spark or fuel, but what do you think? Never did this before got about 197,000 on it.
Old 07-27-2015, 06:34 PM
that_guy's Avatar
that_guy
that_guy is offline
That sort of thing is normally the IAC or battery/ battery connections.
Old 07-28-2015, 09:49 AM
lubeman1's Avatar
lubeman1
lubeman1 is offline
Default Update
Last night after work I finally towed the vehicle back to my shop. I confirmed I had spark ( so not the crank position sensor) but when I tested fuel pressure at the rail I had 0 psi pointing to a bad fuel pump. After a little more research and I confirmed the pump is going bad, I rapped on the tank with a rubber mallet and she fired right up, running on borrowed time now, need to order a new one, any suggestions or just find one on Amazon (local store wants $230 for the module)
Thanks
Old 07-28-2015, 03:09 PM
that_guy's Avatar
that_guy
that_guy is offline
I just put in a bosch one from Amazon a couple weeks ago. Was about $150.
Quick Reply: 2002 D 5.9L no start
