Stalling or no start NO BUS on odometer
Old 02-12-2010, 02:15 PM
TjTazz's Avatar
TjTazz
TjTazz is offline
The "no bus" code strikes again. Truck was plowing for 22 hrs straight and died out of no where. I have a 2002 Dodge Ram V/8 manum ext. cab p/u with an 8" bed pushing a 7 1/2' western minute mount plow. Bought used in 2005, never a problem till recently. First the tranny lost reverse & had to rebuild with a h/d shift kit. Next came the headlights, lost the low beam, Brights worked but the low beam didn't. Had to replace the ground wire @ the module. Most recent is the infamous "no bus", after turning off the truck while refueling we started the truck and after putting it in drive and gave it gas it stalled.
Old 02-12-2010, 02:43 PM
IndyDurango's Avatar
IndyDurango
IndyDurango is offline
Is this your Ram or a Durango?
Old 02-12-2010, 02:44 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
you need to post this in the ram section, this is meant for durangos, but it sounds to me like you have a loose wire somewhere
Old 08-07-2010, 01:02 AM
fastyz400's Avatar
fastyz400
fastyz400 is offline
We'll, My Durango (2000 5.9L) is getting the "no bus" as well. I am trying to determin if it is the ecm that went bad. The problem that I have read on other forums is that the board inside the computer may have cracked or wraped and if you move press in the the plugs your car will run again.
Procedure:
1. Key in the on position
2. Use your hand and press and move the wires around on each of the connectors that goes into the ecm. Listen for the relay to click (Relay box located right behind the battery). Now go back and start your truck. Mine happens to be the connector closest to the firewall. I have read others that the middle plug was the issue.
Here is another writeup on Shut-down Feature in Dodges
http://www.ehow.com/how-does_4924742...l-driving.html
Dodge vehicles have a similar shut down feature. The shut down feature in Dodge vehicles is located in the computer. It is called the auto shut down relay. It will shut the vehicle down if the vehicle rolls over. There is no way to manually turn it back on. If this switch goes bad, the only way to fix it is to replace the computer.
All vehicles have an idle air motor or valve. The idle air is governed by the computer and changes the idle. When you turn on the air compressor, you use some engine resources. This makes the idle speed on the engine drop. The computer senses this drop and sends information to the idle air to turn up the idle so the car does not stall. If this part breaks, when you slow down to a stop or to turn a corner, the car may stall.
Just today, my car wouldn't start by doing the above mentioned. When the transmission was in park. But, when i put it in neutral it starts. This was off & on incident. Decided to replace the neutral safety switch located on my tranny (part 56028181). This part is tied into the ignition system. I'm hoping that this fixes the problem. I will report back if this does not fix the problem. My thoughts are could somehow the swithch was bad, so, while your driving it tells the ecm that tranny just went to park and to shut down the motor? Any thoughts from more experienced techs would be great.
I will be replacing the ecm if the neutral safety switch doesn't fix it.
Old 08-07-2010, 08:10 PM
fastyz400's Avatar
fastyz400
Well the Switch on the tranny didn't work. Truck still stalled. Just ordered a new ecm.
Old 08-09-2010, 02:00 PM
kpmink's Avatar
kpmink
kpmink is offline
Default No bus
i have had the same issues. i should have read looked here first before making my repairs.
i would have saved some money. this site rocks
Old 08-14-2010, 03:00 AM
fastyz400's Avatar
fastyz400
Reman ECM went in 2 days going without a stall. I'll post after 1 week, then 1 month.
Old 08-19-2010, 01:37 PM
fastyz400's Avatar
fastyz400
It's been 1 week. No stalling has occured. Did notice the engine warms up faster & runs hotter now.
Had to put a bottle of that radiator stuff in where it lowers coolant temp. to lower the temps.
It would go to like 225 deg F. after the bottle, it stays at around 210 deg F. in arizona's hot 117-118 deg. weather.
On the highway It cools great.
Before the new computer, it would hold a steady 180-200 F. I've noticed a better gas mileage with the new ecm as well.
Old 08-19-2010, 11:13 PM
Mean Green's Avatar
Mean Green
Mean Green is offline
Are you using water wetter? I've heard good things about it's ability to improve cooling efficiency. I wouldn't use it if you have even the smallest coolant leak though. It reduces the coolants surface tension and will leak a lot easier.
Old 08-20-2010, 12:00 AM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Could just be the sensor. You need to take an accurate temp on the coolant and verify that it is in fact that hot.
Quick Reply: Stalling or no start NO BUS on odometer
