PCM for a Dodge Intrepid '93
Good day,
A friend of mine asked me to find him some auto parts for his Dodge. So far I've found online an Idle Air Control and a Camshaft sensor, but I haven't had any luck with a Power Control Module, which is the last thing I need.
If any of you knows where I could buy it online, I would appreciate the help.
Here's some more info on the car
Modelo: Dodge Intrepid
Combustible: Gasoline
Year: 1993
Motor Number: 2B3ED46TIPH641054
Cilinders: Six, 3300 cc
Transmision: Automatic.
P.S. I just read the forum rules and giving me links to a seller doesn't seem to be prohibited. Hopefully I'm right.
Year: 1993
PCM part numbers fro 93-96
Here is a list of part numbers from 93-96 for the LH (Intrepid) PCM. this may point you in the right direction after you determine the part number you need.see attachment and pick correct pn, then use google shopping and search for your part number (with no space between numbers). Here is a random pn I searched for an example PN 4605427 which was for the 3.3 Eng., Auto. Trans., 1993 (Aft. 2-10-93)
Hope this gets you in the right direction
http://www.google.com/products?q=4605427&hl=en&aq=f
here is a new one selected from the above list
http://cgi.ebay.com/ebaymotors/ws/eB...d=230476543181
I couldnt get the attachment to load so here is the info (sorry its messy this way)
SINGLE BOARD ENGINE CONTROLLER (POWERTRAIN CONTROL MODULE) LH BODY
SINGLE BOARD ENGINE CONTROLLER, (Powertrain Control Module) ***
Part # Description
4653 025 3.3 Eng., Auto. Trans., 1993 (Up To 2-10-93)
4605 427 (Aft. 2-10-93)
4653 027 3.3 Eng., Auto. Trans., Calif., 1993 (Up To 2-10-93)
4605 428 (Aft. 2-10-93)
4605 300 3.5 Eng., Auto. Trans., 1993 (Up To 1-27-93)
4605 429 (Aft. 1-27-93)
4605 310 3.5 Eng., Auto. Trans., Calif., 1993 (Up To 1-27-93)
4605 435 (Aft. 1-27-93)
4605 320 3.5 Eng., Auto. Trans., (P225/60 VR16 BSW) w/o RFI, 1993
(Up To 1-27-93)
4605 436 (Aft. 1-27-93)
4605 330 3.5 Eng., Auto. Trans., Calif. (P225/60 VR16 BSW) w/o RFI,
4605 437 (Aft. 1-27-93)
4653 130 3.3 Eng., Auto. Trans., w/o Catalyst, w/RFI, 1994, MIDEAST
4653 131 3.3 Eng., Auto. Trans., w/o RFI, 1994
4606 550 1995
4653 133 3.3 Eng., Auto. Trans., Flex Fuel, w/o RFI, 1994
4606 554 1995
4605 512 3.3 Eng., Flex Fuel, w/o RFI, Calif.
4653 134 3.5 Eng., Auto. Trans., (w/o P225/60VR16 BSW, w/o RFI) 1994
4606 556 1995
4653 135 3.5 Eng., Auto. Trans., w/o RFI, Calif., 1994
4653 136 3.5 Eng., Auto. Trans., (w/P225/60 VR16 BSW, w/o RFI) 1994
4606 560 1995
4605 137 3.5 Eng., Auto. Trans., w/o RFI, 1994, Calif.
4606 193 3.5 Eng., Fed. & Calif., RFI, w/225/60-BSW
4653 129 3.5 Eng., Auto. Trans., 1994, EUROPE
4606 578 1995 3.5 Eng., EUROPE
4606 582 1995 3.3 Eng., Leaded Fuel, EUROPE
4606 566 1995 w/RFI, Calif., 3.3 Eng.
4606 552 1995 w/o RFI, Calif., 3.3 Eng.
4606 564 1995 3.3 Eng., Gas
4606 568 1995 w/RFI, 3.3 Eng. Flex Fuel
4606 570 1995 3.5 Eng., Flex Fuel
4606 086 995-96, 3.3 Flex Fuel, Calif., w/RFI
4606 084 1995-96, 3.3 Eng., Flex Fuel, Calif., w/o RFI
4605 610 1996, 3.3 Eng, Fed. Emissions
4605 618 1996, 3.5 Eng., Calif. Emissions
4897 404AA 1996, 3.5 Eng., Federal Emmisions, P225/60VR16 Tires
4897 403AA 1996, 3.5 Eng., Federal Emissions, w/o P225/60VR16 Tires
4605 624 1996, 3.5 Eng., EUROPE
4605 626 1996, 3.3 Eng., Leaded Fuel, EUROPE
4605 628 1996, 3.3 Eng.
MODEL CODES: —————————————————————————————————————————————————— ———————————————
Chrysler = (CH41 = New Yorker, CP41 = LHS, DH41 = Intrepid(Canada), DP41 = Intrepid ES(Canada), LP41 = Concorde)
DODGE = (DH41 = Intrepid(USA), DP41 = Intrepid ES(USA))
EAGLE = (XP41 = Vision ESI, XS41 = Vision TSI)
BODY STYLES: —————————————————————————————————————————————————— ———————————————
41 = 4 - Door Sedan ENGINE: 3.3L (EGB)
3.5L (EGE) 24 Valve
Part # Description
(Up To 1-27-93)
4606 550 1995
4606 554 1995
4606 556 1995
4606 560 1995
3.5L (EGE) 24 Valve
Last edited by kurts2; 07-07-2010 at 05:40 AM. Reason: add attachment data to post
