What you need for a 4 barrel swap
Old Sep 24, 2014 | 11:10 AM
emnestor's Avatar
emnestor
Default What you need for a 4 barrel swap
I just swapped out my old 2 barrel and lean burn system, on my 87 D100, during a restoration. Since I was new to the first gen Dodge trucks I had to do a lot of asking and searching to find out what you need to swap to a edelbrock 4 barrel and how to adapt your transmission kickdown linkage to a cable. I noticed most folks were using the Lokar throttle cable and kick down cable system, but I wanted to retain my stock throttle cable. So after some searching I found BPE (Bouchillon Performance Engineering). They have everything you need and a Kick down cable kit all in one Part # 3350. So heres the info.
Here is the link to the kit http://www.bpeusa.com/BPEtkdc.asp and here is the link to their instructions http://www.bpeusa.com/BPEtkdcInstructionsNEW.asp
First you need something to mount everything to. BPE makes a throttle cable mount that bolts onto your Eddy Carb. Part # BPE3395 which will mount your stock throttle cable and the new kickdown cable bracket
Next you will need two parts to mount everything to your carb. First you need part # 1481 from Edelbrock which allows mopar style throttle cables to mount to the carb. Also, you will need the mounting plate that holds the kickdown cable to the carb, which is provided in the kit, and mounts on top of the Edelbrock part #1481 .
On the underside you have everything you need to install from the kit. Mounting bracket, the arm for your kickdown that replaces the stock one, and the return spring and mount
here is a link to my Restoration thread https://dodgeforum.com/forum/1st-gen...ion-build.html
And here is a link to a slide show from beginning to now with notes
http://s115.photobucket.com/user/the...ml?sort=6&o=80
Old Oct 6, 2014 | 01:43 PM
LowNSloan86's Avatar
LowNSloan86
thank you in advance for when i have the time and money to do this!!!!
Old Oct 6, 2014 | 10:51 PM
moe7404's Avatar
moe7404
edelbrock does NOT know how to jet a carb. 1. hint change only jets. OR rods at a time if you change both you cant guess what the change was. 2. hint change jets and rod to more like the size of OEM carter carbs. 3. if the jet does not come out easy dont force, that will strip the jet out. 4. hint there is a trick to get difficult jets out. take it all apart, get a small torch on the jet, when the color of the flame changes hit it with water. let it cool should work. i have done this only once, but it did work. But dont put the jet hard, just very lite tightness. and most edlbrock carbs have the rod with to much diff from the power step to the cruse step. hint check dia in the rods in an O.E.M. chrysler AFB.
Old Oct 7, 2014 | 08:14 AM
emnestor's Avatar
emnestor
Thanks Moe7404 great addition!
